Danes je 10 Avg 2020 17:22
Napiši novo temo Odgovori na temo  [ 38 prispevkov ]  Pojdi na stran 1, 2  Naslednja
 Naslov prispevka: Ferrari F12 Berlinetta
OdgovorObjavljeno: 05 Feb 2012 21:52
Prispevkov: 13091
Ferrari F620 GT na Salonu u Ženevi
VIR
 Naslov prispevka: Re: Ferrari 620 GT
OdgovorObjavljeno: 19 Feb 2012 20:44
Prispevkov: 13091
Ferrari F620 na Salonu u Ženevi
VIR
OdgovorObjavljeno: 21 Feb 2012 15:41
Prispevkov: 13091
OdgovorObjavljeno: 24 Feb 2012 09:53
Prispevkov: 13091
OdgovorObjavljeno: 24 Feb 2012 20:07
Prispevkov: 13091
VIR
OdgovorObjavljeno: 29 Feb 2012 14:16
Prispevkov: 13091
VIR
 Naslov prispevka: Re: Ferrari F12 Berlinetta
OdgovorObjavljeno: 29 Feb 2012 14:52
a jst prov vidm, da je na sovoznikovi strani nek obratomer in hitrost?
OdgovorObjavljeno: 29 Feb 2012 14:55
Prispevkov: 13091
djz3l3 napisal/-a:
Zgleda že tako, da sopotnik vid ko se voziš čez 300 na uro. :D
OdgovorObjavljeno: 29 Feb 2012 15:57
Prispevkov: 13091
OdgovorObjavljeno: 29 Feb 2012 20:46
Prispevkov: 13091
NEW MODEL - FERRARI F12BERLINETTA
Ferrari has announced the new F12berlinetta today ahead of its world debut in Geneva; the V12 mid-front-engined sports car which replaces the 599 GTB Fiorano offers all-round advances which make it the fastest Ferrari ever.
The F12berlinetta aims to deliver impressive performance from a much more powerful version of the FF's 6.3 litre V12 powerplant and that is combined with an innovative new design that hopes to meld classic Maranello design themes along with extreme aerodynamics. Revealed to the world for the first time online today in preparation for its official debut at the Geneva International Motor Show, the debuting F12berlinetta, finished in a new Rosso Berlinetta three-layer colour.
This is, in fact, the most powerful and high-performance Ferrari road car ever launched thanks to the efficient engine – in terms of mechanical, combustion and fluid-dynamics efficiency – which, together with advanced vehicle architecture, aerodynamics, components and electronic controls, guarantee improved driving involvement whatever the road or track.
Ferrari’s traditional transaxle layout has been revolutionised to match the more extreme performance of the car. The wheelbase has been shortened and the engine, dashboard and seats have been lowered in the chassis, while the new layout of the rear suspension and gearbox enabled Ferrari’s engineers to make the rear volume of the car smaller. The overall result is a very compact car with a lower centre of gravity that is further back in the chassis, and a level of aerodynamic efficiency that sets new standards.
Scaglietti, renowned for its expertise in aluminium materials and construction, designed an all-new spaceframe chassis and bodyshell using 12 different kinds of alloys, some of which have been used here for the first time in the automotive sector, and employing new assembly and joining techniques. This has resulted in a 20 per cent increase in structural rigidity while reducing weight to just 1525 kg (70 kg less than the previous V12 coupé) with an ideal distribution between the axles (54 per cent over the rear).
The F12berlinetta’s 6262cc 65° V12 engine delivers unprecedented performance and revs for a naturally-aspirated 12-cylinder. Its maximum power output is 740 CV which translates to a specific output of 118 CV/l. Torque reaches a peak of 690 Nm, 80 per cent of which is already available at just 2,500 rpm, and which provides an unrelenting surge of acceleration all the way to the 8,700 rpm limit. The engine is mated to the F1 dual-clutch transmission, which has closer gear ratios developed specifically for this car’s performance. The F12berlinetta boasts a weight-to-power ratio of just 2.1 kg/CV .
Fuel consumption has been reduced by 30%, with CO2 emissions of just 350 g/km – figures which put the F12berlinetta at the top of the high-performance league. These results have been obtained by extensive research and development which focused on efficiencies of the whole vehicle: engine, aerodynamics, tyres and weights.
Similarly excellent results have been obtained with the car’s aerodynamic development, thanks to the integration of the design process with extensive computational fluid dynamics (CFD) simulations and lengthy testing in the wind tunnel. The car's downforce has been boosted by 76 per cent (123 kg at 200 km/h) while drag has been significantly reduced (the Cd is just 0.299).
These results come courtesy of two new solutions. The first of these is the aero bridge which uses the bonnet to generate downforce by channelling air away from the upper part of the car to its flanks where it interacts with the wake from the wheel wells to decrease drag. The second is Active Brake Cooling, a system that opens guide vanes to the brake cooling ducts only at high operating temperatures, again reducing drag.
The F12berlinetta’s technical specifications are completed by Ferrari’s latest generation carbon-ceramic brakes (CCM3) and the evolution of the magnetorheological suspension control system (SCM-E). As is now traditional with all Ferraris, its control systems (E-Diff, ESP Premium, F1-Trac, and high-performance ABS) are all fully integrated.
The result is that the new Prancing Horse 12-cylinder accelerates from 0-100 km/h in 3.1 seconds and from 0 to 200 km/h in 8.5 seconds. It also completes a lap of the Fiorano circuit in 1’23”, faster than any other Ferrari road car. Benchmark performance and maximum driving involvement are guaranteed by immediate turn-in, with smaller steering wheel angles, and increased cornering speed. Stopping distances have also been drastically reduced.
The design of the F12berlinetta is a result of the collaboration between the Ferrari Styling Centre and Pininfarina and is a perfect balance of uncompromising aerodynamics with harmonious proportions interpreting the typical elements of Ferrari’s front-engined V12 cars in an original and innovative way. A coupé with sleek, aggressive lines whose compact exterior dimensions conceal exceptional in-car space and comfort. The new Frau leather interior aims to highlight the balance of advanced technology and handcrafted detailing. In the middle of the light and lean dashboard, there are new carbon fibre and aluminium air vents clearly inspired by the aeronautic field.
The cabin has been designed for maximum usability of the interior space with additional luggage capacity behind the seats, which can also be reached thanks to the large aperture offered by the tail-gate. With the cockpit designed around the driver, typical of all Ferraris, the 'Human Machine Interface' approach is emphasised, grouping all the major commands within immediate reach to guarantee maximum ergonomics for the most involving driving experience.
TECHNICAL SPECIFICATIONS
Engine
Type 65-degree V12
Total displacement 6262 cc
Maximum power output 740 CV at 8500 rpm
Maximum torque 690 Nm at 6000 rpm
Dimensions and weight
Length 4618 mm
Width 1942 mm
Height 1273 mm
Dry weight 1525 kg
Weight distribution 46% front, 58% rear
Weight-power ratio 2,1 kg/CV
Performance
Maximum speed over 340 km/h
0-100 km/h 3.1 seconds
VIR
OdgovorObjavljeno: 02 Mar 2012 13:44
Prispevkov: 13091
VIR
OdgovorObjavljeno: 04 Mar 2012 11:57
Prispevkov: 13091
Ferrari F12berlinetta live in Genève
VIR
OdgovorObjavljeno: 05 Mar 2012 22:40
Prispevkov: 13091
Ferrari F12berlinetta: prve slike iz Ženeve
VIR
OdgovorObjavljeno: 05 Mar 2012 23:38
Prispevkov: 1154
Kraj: Vipava
uff ta srebrna barva :007.gif:
Mazda 6
OdgovorObjavljeno: 06 Mar 2012 17:59
Prispevkov: 13091
OdgovorObjavljeno: 06 Mar 2012 18:58
Prispevkov: 13091
VIR
OdgovorObjavljeno: 07 Mar 2012 17:40
Prispevkov: 13091
VIR
OdgovorObjavljeno: 07 Mar 2012 21:34
Prispevkov: 13091
Se že špekulira o izgledu GTO verzije :007.gif:
OdgovorObjavljeno: 07 Mar 2012 21:45
Prispevkov: 2824
abarth napisal/-a:
I'm inlove :033.gif:
OdgovorObjavljeno: 07 Mar 2012 21:46
Prispevkov: 353
Kraj: Tolmin
dreamer kr lot se šparat, pa si ga boš lahk kupu ka boš meu 80 let :škrbina:
