Danes je 03 Jun 2020 16:58
Napiši novo temo Odgovori na temo  [ 129 prispevkov ]  Pojdi na stran Prejšnja  1, 2, 3, 4, 5 ... 7  Naslednja
OdgovorObjavljeno: 22 Nov 2007 22:32
Prispevkov: 80
Kraj: Dolenjska
Študija pande za leto 2010
Citiram:
New Fiat Panda 2010. After to have "put the hands" on the future Fiat One, to have proposed some beautiful one varying of the new Fiat 500 (like 500 Fiat Giardiniera, 500 Fiat Cabrio) and to have delineated a complete range of Fiat Bravo (Fiat Bravo Cabrio, Fiat Bravo Coupè, Fiat Bravo Cross, Fiat Bravo Station Wagon), the talentuoso designer of Infomotori.com this time has realized something of superlativo: a personal interpretation as well as how much credible one of the next generation of Fiat Panda, innovative utilitaria poured them and, definitive arm in order to yesterday face the city traffic like today. The Panda new would have to be the first car entire developed from Workshop 83, revived center Fiat style destined to give birth look of all the new creatures of the Ingot. In beyond 12000 meters you squared of surface, the team of designer Fiat is engaged to suggellare the happened one recently obtained thanks to one antichi sage modern feature and fusion stilemi, tradition and new tendencies.
New Panda 2010 is introduced compact and aggressive, also maintaining to wide gestibili spaces with total flexibility. The snout is characterized from calenders rectangular and prominente inaugurated from the Great Point: this particularitity confers dynamism to with, to the par of the width inferior air inlet much similar to that sight on Fiat Bravo. The front beacons are composed from two rows of able LED of better performances regarding the Xenon technology, consuming but tenth of the electric power demanded from it celebrates discharge lamps of gas. The course of the lateral vetratura remembers the Panda in production currently, rendering the new identifiable version to the first blow of eye. The line of rather high belt and the passaruota pronounce to you donate to the Panda new a sportiveggiante nature, beyond transmitting to solidity and emergency. Insomma, the eye is satisfied, but this plan appears concrete, realizable.
Also the posterior sight does not disappoint... indeed! Beautifulst the rear window hexagonal, similar to that approval on Fiat Bravo, is encircled from one wraps burnished that it accommodates all the tail lights. Here we deal one of the aspects more innovated you than this plan: all the posterior fanaleria of the Panda new is based on able LED to fuse shape and colors in the wished function: the lights of stop will be obviously red and of triangular shape, universal symbol of danger. The direction pointers, places to the ends of the space available, are represent to you like yellow arrows. Nothing simpler, nothing than more fastly comprehensible, to total benefit of the emergency.
The inner ones of New Fiat Panda do not disappoint, sfoggiando the ennesima "chicca" technological. The commandos of the multimediale system of edge are replied in the panel of forehead to the passenger under shape of OLD-touch screen. You it seems complicated? In truth not more intuitivo is null. Several the commandos (as the choice of the song or the regulation of the volume) is literally projects to you on the plancia: correspondent to the wished action will be sufficient to graze the "virtual key". To much innovation contrappone the found recovery of a brilliant one of Giorgetto Giugiaro, designer of originates them Fiat Panda: we refer to the mythical "pocket" situated under plancia, the practical and able space action to receive objects of every risen.
We close assuming for the Panda new innovative and ecological motorizations: it would appeal to one hybrid version to us, binding together the propulsion equipped innovative electrical worker to the bicylindrical one from 900cc of MultiAir technology previewed for the next year. Fateci to know what thoughts of these pregevole exercise of design through the comments. We of the writing of Infomotori.com, if still he had not been understood, of are enthusiastic!
21/11/2007 Infomotori.com Teams
OdgovorObjavljeno: 22 Nov 2007 22:49
Prispevkov: 3656
prototip ampak tehnike se razvijajo tko d je marsikej možn!!!
:040.gif: go fiat
OdgovorObjavljeno: 23 Nov 2007 13:57
Prispevkov: 5481
alesdrolec napisal/-a:
prototip
To ni prototip. Te skice niso uradne in niso prišle iz Fiata. To je spet fotošop fantov z infomotori.com, k majo preveč cajta, kako si oni predstavljajo naslednico :026.gif:
OdgovorObjavljeno: 01 Mar 2008 10:04
Prispevkov: 627
Kraj: Dravograd
Nova Fiat Panda bo v prihodnosti mogoče oblikovno podoben Fiat 500. Ko bodo zamenjali trenutno Pando se bo Fiat Crew orientirala na sedaj zelo uspešnem Retro-looku.
To je samo render (ne od Fiata) kako bi lahko zgledala :D
OdgovorObjavljeno: 01 Mar 2008 10:07
Prispevkov: 3656
Ozi napisal/-a:
mislm d nebi velik zgrešil k je kr všečna!
OdgovorObjavljeno: 15 Jun 2010 12:24
Prispevkov: 13088
Fiat Panda 2011 : P’tite mignonne
(vir: http://blogautomobile.fr/fiat-panda-201 ... onne-68346)
OdgovorObjavljeno: 30 Jun 2010 18:30
Panda fan
Prispevkov: 276
Kraj: LJ
Sam tazadna fotka je pa kr no... :)
OdgovorObjavljeno: 30 Jun 2010 18:44
Prispevkov: 1422
neee to ni več panda... sejn je lep avtoček.. sam kako bojo potem to nardili offroad? panda mora bit višja, prednja maska bol robata to je lep mesni avtoček..sam tega ma fiat že nekaj.
OdgovorObjavljeno: 30 Jun 2010 23:45
Panda fan
Prispevkov: 276
Kraj: LJ
Zgleda bolj izpeljanka iz 100HP pande kot pa iz navadne.
OdgovorObjavljeno: 12 Jul 2010 20:24
Prispevkov: 13088
(vir: http://www.quattroruote.it/news/articol ... ice=260291)
OdgovorObjavljeno: 18 Avg 2010 22:02
Prispevkov: 961
Če se ne motim danes Panda praznuje 30 let :104.gif: :104.gif: :032.gif:
OdgovorObjavljeno: 19 Avg 2010 07:21
Prispevkov: 13088
hydro_freak napisal/-a:
Leta 1980 je bila predstavljena, ne vem pa če je bil 18 avgust. :)
OdgovorObjavljeno: 19 Avg 2010 07:47
Panda fan
Prispevkov: 276
Kraj: LJ
Ne moreš, da je ne bi mel rad :D
OdgovorObjavljeno: 18 Dec 2010 18:03
Prispevkov: 13088
Še vedno in ...
FIAT PANDA CROSS 4X4 COLLECTS UK OFF ROAD HONOUR
The rugged Fiat Panda Cross has collected an off-roading honour in the UK in the "Junior Crossover" class in Total Off Road magazine’s 4x4 of the Year awards.
Launched in July 2005, however the Panda Cross 4x4 didn't arrive in the UK until 2008 due to the tiny SUV's four-wheel-drive platform not being engineered for right hand drive, the highly capable car has continued to be a favourite not just among customers but with media experts as well.
Total Off Road’s judges praised the Panda’s styling, handling, ease of controls and its punchy 1.3 16v MultiJet turbodiesel engine. The car’s crisp steering, ride and brakes were also highlighted by the magazine’s testers, as the Panda Cross beat 11 other vehicles in this class to the title. “The Panda Cross has loads of style but plenty of substance too,” say the awards’ judges. “It’s great fun in town, a rough diamond on B-roads and pretty acceptable on the motorway. And it can do remarkable things off road.”
“The Panda Cross is one of a long line of Pandas that have surprised and delighted customers for years,” says Elena Bernardelli, marketing director, Fiat Group Automobiles UK and Ireland. “I am pleased that it is still collecting top honours – it certainly deserves them.”
As with any Panda, the Cross’s fuel consumption and emissions are low. It returns 42.1 mpg in the urban cycle, 67.3 mpg extra-urban, and 54.3 mpg combined. The CO2 figure is 136 g/km. Standard equipment in the UK includes ESP with Hill Holder, air conditioning, alloy wheels, radio/CD/MP3 player with steering wheel audio controls, and electric power steering. The Panda Cross costs £13,695 on-the-road in the UK.
(vir: http://www.italiaspeed.com/2010/cars/fi ... /1712.html)
OdgovorObjavljeno: 04 Jan 2011 23:59
Prispevkov: 2127
Kraj: Škofja Loka
Govori se da naj bi se brazilski uno v evropi znašel kot nova panda.
Meni je všeč :D
OdgovorObjavljeno: 16 Apr 2011 18:20
Prispevkov: 13088
(vir: http://www.infomotori.com/auto/2009/09/16/fiat-panda/)
 Naslov prispevka: Re: Fiat Panda
OdgovorObjavljeno: 11 Maj 2011 20:26
Prispevkov: 13088
Fiat Panda 2012 : Son bon profil mis à nu….
(vir: http://blogautomobile.fr/fiat-panda-201 ... z1LyME23nm)
OdgovorObjavljeno: 19 Maj 2011 19:32
Prispevkov: 13088
(vir: http://www.alvolante.it/news/fiat_panda ... -463151044)
OdgovorObjavljeno: 23 Jun 2011 18:24
Prispevkov: 13088
VIR
OdgovorObjavljeno: 23 Jun 2011 20:15
Panda fan
Prispevkov: 276
Kraj: LJ
Ulala, dizel z 95 hp.. njamsk njamsk! Končno nekaj nepodhranjenega... :D
Oblika mi pa vsaj trenutno ne potegne preveč. Morda bo kaj bolš pol, ko bodo uradne fotke.
