Danes je 23 Feb 2020 06:01
Napiši novo temo Odgovori na temo  [ 65 prispevkov ]  Pojdi na stran Prejšnja  1, 2, 3, 4  Naslednja
OdgovorObjavljeno: 29 Jan 2011 01:01
- nič mi ni všeč -
Prispevkov: 1845
Meni je všeč.. je nekaj posebnega, je pa res da je podoben Z3 coupeju. Osnovna oblika. Ima pa popolnoma Ferrarri poteze. Zakaj na 4wd je pa jasno. miljoni konjev katere bo zmogel motor, je za vsak dan težko krotiti. Plus dodatna tržna niša.
Vedno je zanimivo kako se oglašajo o pogonu ravno pripadniki 60 konjskih fwd strojev, kateri imajo handling podoben samokolnici.
Če 4wd ne bi bil tako uporaben bi verjetno večina proizvajalcev imela v programu samo FWD ali RWD. O besedi duša pa naj bo mir. Ker vas večina ne ve niti kaj želite povedati s tem. Noben RWD ne bo nikoli boljši v celoti kot AWD, saj fizikalnih zakonov ni mogoče podreti.
OdgovorObjavljeno: 30 Jan 2011 14:08
Metalik oranžna
Prispevkov: 1780
Kraj: Velenje
Citiram:
So what about the four-wheel drive, then? Uniquely, power is also taken off the front of the engine, which is behind the front wheel centres. It's fed to a compact lightweight unit containing a set of clutches that can progressively feed in torque to a tiny integrated gearbox and front diff. It has only two gears, roughly the equivalent of third and seventh in the main box. How can this be? Because the clutches are always slipping under electronic control, and the front tyres would never be able to make use of all the V12's torque in first or second.
What this means is the car's electronics can smoothly dial up a portion of drive to the fronts if they predict a loss of traction at the back. Yes, they're predictive as well as reactive. And they only do this in the road and slippery-road settings of the steering-wheel manettino. In the more hardcore modes, you can still run it as pretty well entirely rear-drive.
Na kratko, 4WD sistem ni konvencionalni, za pogon sprednjih koles ma še en mali menjalnik in diferencial, moč pa dobivata iz sprednjega dela motorja. Neki takega pač.
OdgovorObjavljeno: 05 Feb 2011 20:33
Prispevkov: 13085
(vir: http://www.italiaspeed.com/2011/cars/fe ... /0402.html)
OdgovorObjavljeno: 16 Feb 2011 10:51
Prispevkov: 13085
OdgovorObjavljeno: 24 Feb 2011 08:37
Prispevkov: 13085
(vir: http://www.italiaspeed.com/2011/cars/fe ... /2302.html)
OdgovorObjavljeno: 24 Feb 2011 22:18
Prispevkov: 13085
Ferrari FF :muahahaha:
(vir: http://blogautomobile.fr/ferrari-ff-sup ... deo-103126)
OdgovorObjavljeno: 24 Feb 2011 22:39
Metalik oranžna
Prispevkov: 1780
Kraj: Velenje
Bel, pa z črno sprednjo mrežo...ubija. :aaa:
OdgovorObjavljeno: 28 Feb 2011 22:46
Prispevkov: 13085
... prve fotke iz Ženeve 2011
(vir: http://www.infomotori.com/auto/2011/01/ ... ri-ff/2/7/)
OdgovorObjavljeno: 01 Mar 2011 14:19
Prispevkov: 13085
[img][1024:683]http://www.omniauto.it/awpImages/photogallery/2011/12750/photos1280/ferrari-ff-ferrari-four-_177351.jpg[/img]
[img][1024:682]http://www.omniauto.it/awpImages/photogallery/2011/12750/photos1280/ferrari-ff-ferrari-four-_177353.jpg[/img]
[img][1024:682]http://www.omniauto.it/awpImages/photogallery/2011/12750/photos1280/ferrari-ff-ferrari-four-_177354.jpg[/img]
[img][1024:682]http://www.omniauto.it/awpImages/photogallery/2011/12750/photos1280/ferrari-ff-ferrari-four-_177352.jpg[/img]
[img][1024:682]http://www.omniauto.it/awpImages/photogallery/2011/12750/photos1280/ferrari-ff-ferrari-four-_177350.jpg[/img]
[img][1024:767]http://www.omniauto.it/awpImages/photogallery/2011/12750/photos1280/ferrari-ff-ferrari-four-_177355.jpg[/img]
[img][1024:767]http://www.omniauto.it/awpImages/photogallery/2011/12750/photos1280/ferrari-ff-ferrari-four-_177356.jpg[/img]
[img][1024:767]http://www.omniauto.it/awpImages/photogallery/2011/12750/photos1280/ferrari-ff-ferrari-four-_177357.jpg[/img]
(vir: http://www.omniauto.it/magazine/14711/f ... rrari-four)
OdgovorObjavljeno: 02 Mar 2011 15:33
Prispevkov: 13085
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_7.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_8.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_9.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_23.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_27.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_28.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_34.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_37.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_38.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_43.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_45.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_47.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_48.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_50.jpg[/img]
[img][1024:686]http://www.omniauto.it/awpImages/photogallery/2011/13116/photos1280/ferrari-ff-al-salone-di-ginevra-2011_52.jpg[/img]
(vir: http://www.omniauto.it/ginevra2011/stand/705/ferrari)
OdgovorObjavljeno: 08 Mar 2011 21:09
Prispevkov: 13085
OdgovorObjavljeno: 11 Mar 2011 08:31
Prispevkov: 13085
OdgovorObjavljeno: 24 Mar 2011 20:15
Prispevkov: 13085
OdgovorObjavljeno: 25 Mar 2011 09:22
Prispevkov: 13085
Making of video
OdgovorObjavljeno: 03 Apr 2011 11:42
Prispevkov: 13085
(vir: http://www.italiaspeed.com/2011/cars/fe ... llery.html)
OdgovorObjavljeno: 07 Apr 2011 18:56
Prispevkov: 13085
 Naslov prispevka: Re: Ferrari FF
OdgovorObjavljeno: 03 Jan 2012 08:12
Prispevkov: 13085
OdgovorObjavljeno: 12 Jan 2012 22:15
Prispevkov: 13085
OdgovorObjavljeno: 03 Feb 2012 09:06
Prispevkov: 13085
Markku Alen na snegu s ferrarijem FF
OdgovorObjavljeno: 03 Feb 2012 15:35
clean,podn,rob,DOJČE ®
Prispevkov: 3723
Kraj: vrhnika
zanimivo kok je zdej naenkrat tok na snegu slikan pa sneman...oz v slapsih pogojih, prej pa nikoli
